Help verifying H code engine
Hi All,
Does anyone know how to tell the difference between the 1968 coronet 383-4bbl that makes 330HP (VIN code G) and the 383-4bbl 335HP (VIN code H), just by looking at it? Access is limited. But here is what I know:
I was able to see the right lower side of the block (just above the oil pan). Definitely no flat spot with VIN or other numbers stamped on it.
Pad next to distributor has "D383" without "HP" next to it. Below that and to the right is the number "2".
Motor is Turquoise
Air cleaner is not double snorkel
Fender tag shows "62" as the engine code
Since the VIN is an "H" code and the fender tag and build sheet show a 62, I am trying to verify this is the original engine.
I am also not sure if all the research I am doing is yielding the wrong result and the original engine will not be "HP" and instead will just be the 383-4bbl 330HP version.
Any help would be appreciated
1968Coronet500 Wrote:Hi All,
Motor is Turquoise
AFAIK,
1. The 335hp version was only installed in Road Runner's and Super Bee's in '68
2. VIN's weren't stamped on the lower pan rail in '68, that started in '69.
3. Engine should be turquoise in '68, I believe the orange engines started in '69 also.
Try checking the exhaust manifold numbers, I believe that the manifolds were the same in '68 and '69 for the HP engines. If so, the passenger side manifold should be casting #2806900 and driver's side should be casting # 2843992. If you have those manifolds, I think you have an HP engine. If not, then it is the 330hp version.
But then, does anybody really know for sure? A lot of people claim to be experts, I only claim to NOT be one of them. Good luck and I hope somehow this helps you out.
Thanks! I'll try to get a look at the the exhaust manifolds and possibly get a casting number off the heads.
Mopars & Missiles Wrote:AFAIK,
1. True
2. True. A 68 Vin may or may not be on the back of the block by the oil sending unit.
3. True
An "H" in the VIN and 62 on the tag only tell you it was a 383-4bbl. It does not tell you which HP version is in the car.
  1969 Coronet A39 Super Bee Scat Pack Spring Special option code 1958300 2 15 10 hours ago
  Recommend engine swap shop fitzyb5 2 2,937 10-13-17, 11:25 PM
Last Post: Dingusboy
  Engine problems all opinions welcome. Warhawkfight34 20 8,227 08-22-17, 08:23 AM
Last Post: Warhawkfight34
  Looking for 67 R/T engine bay pictures jworz71 12 8,387 12-19-16, 11:13 PM
Last Post: jworz71
  Engine and transmission questions odot365 14 9,158 08-21-16, 09:21 PM
  Is this a real A12 M code Super bee? Warhawkfight34 9 5,668 04-07-16, 11:48 PM
Last Post: R/T XTC
  Almost done detailing the engine bay. Heres some updated pics. Warhawkfight34 16 10,511 01-26-15, 11:37 AM
  1960 383 cross ram engine alwayslooking 0 2,573 12-24-14, 11:42 PM
Last Post: alwayslooking
  Engine is FINALLY INSTALLED Warhawkfight34 10 6,213 06-12-14, 08:29 PM
Last Post: dadstoy65
