Transmission Fluid Leak
I have a leak and I have pin pointed it to the base of the dipstick tube... this may be an easy fix but I didn't just want to get down there and start prying on stuff and break it. Does that screw into the base? Does it just slide into some sort of seal and the seal needs to be replaced? I put a bit of permatex sealant on it but it just leaked underneath it and got out anyway so I peeled that off... What's the best way to fix it? (I checked the manuals and it's not in there, probably because it's such a minor job)
There is an o-ring on the end of the tube. There is a bracket on it that bolts to the trans bellhousing. Unbolt it and the tube will pull out - on the early transmissions there is also a 1/4-20 bolt right next the tube where it enters the case, if it has it it will have to be removed too. Dont forget a drain pan (oil will come out)
  coolant leak beefman 2 3,455 04-03-17, 01:04 PM
Last Post: beefman
  Age old 727 tranny pan leak. Hibbing_Coronet_500 4 4,538 10-28-13, 08:08 AM
  Quick shift trans fluid BooBoo 2 3,782 09-22-13, 05:12 AM
Last Post: Sedanman67
  727 transmission issues hammond472 3 4,341 08-22-13, 01:08 AM
Last Post: hammond472
  Transmission swap question Avenger 9 8,031 08-21-13, 02:41 PM
Last Post: duke51
  NEW PROCESS A-833 TRANSMISSION ISSUE Markfive 4 4,950 08-19-13, 06:35 PM
Last Post: 4264door
Last Post: harold prentice
  Oil Leak markbob@ameritech.net 13 8,316 07-01-13, 03:00 PM
  904 transmission pan Coronet 14 13 10,717 05-25-13, 12:43 AM
Last Post: Coronet 14
  727 leak Avenger 86 26,818 05-25-13, 12:06 AM
