Age old 727 tranny pan leak.
Hey gang.
Down to the last few bolts pulling my 727 from the car. I had the pan off to drain, then put the pan back on to catch the drips until it was ready to lower it. I pulled the pan one last time and it only had a few ounces in the pan. Dumped it out and went over the tranny flange with a scraper one last time using gravity to let the junk fall.
To my surprise.... there is another hole.... holly crap. its next to the dipstick. Omg the area of leakage.
I poked and probed this hole in the flange by the dipstick.
It goes up and thru. packed with dirt and sand and crud.
After the clean-up? Its a no brainer. One of the 1/4 pipe plugs was missing. Fluid was seeping between the gasket and up that crud filled hole. I never noticed it and I would not have noticed the plug missing because the exhaust pipe runs right next to the tranny.
I ran a 1/4 tap. cleaned the threads and ran a 1/4 x 1/2 bolt from the top down using tread lock gel. Then filled up the bottom void with RTV.
The original reason I was pulling my 727 was to cure this never ending leak, 4 pan gaskets of all costs and quality. Figured I had a bad front seal? Or a cracked case? I knew I had to get it out to get a look at it.
Keep going? Or put it back together?
put it back together. hmmmm i have a never ending leak in the 727 in my dart that is in the same area. Sad
Feels good to find a pesky problem!
It's fixed!! It's fixed!! No more cardboard to catch oil leaks.
$3.99 fiber reusable gasket on eBay. Shipping cost more. I'm happy!
  coolant leak beefman 2 3,455 04-03-17, 01:04 PM
Last Post: beefman
  Transmission Fluid Leak Zaq 1 3,163 07-12-13, 08:45 PM
Last Post: harold prentice
  Oil Leak markbob@ameritech.net 13 8,316 07-01-13, 03:00 PM
  727 leak Avenger 86 26,818 05-25-13, 12:06 AM
  Small coolant leak Avenger 2 3,171 04-07-13, 01:04 AM
  1966 Coronet Engine and Tranny choices Advice Rob 10 8,294 02-22-13, 02:12 PM
Last Post: fastcoronet
