727 leak
#31
Damn things wont budge.. Its pissing me off lol..stupid flex bolts
link 2 wrenches together...needs more torque lol
Gotta love Loctite Red!
You can try a little heat like with a butane torch and heat the head of the bolt, wait a minute for the heat to soften the loctite then give er all you got.
They can be a real bugger. Just keep trying and they will break free. The key is to stop any crankshaft rotation, then having enough torque on those bolts. I know what you are going through, bruised knuckles are the order of the day.
You might be able to use a shallow socket with a longer ratchet and spin the assy until the ratchet head hits the engine block, then the bolt will give. Once you figure out the trick, the others should be easy.
How about using a 3/8" air ratchet and a 6 point impact socket?
You just want to jump into the computer and help sometimes, maybe someday they can do that .
Might sound silly?
Righty tighty... Lefty loosey...
4264door Wrote:How about using a 3/8" air ratchet and a 6 point impact socket?
A ratchet or an impact wrench? im thinking ratchet Smile I even have a nice air compressor and was just like duhhhh lol
-John
[Image: IMG_1711.jpg]
Last Post: beefman
  318 POLY INTAKE OIL LEAK harold prentice 3 4,319 07-08-13, 05:25 PM
Last Post: harold prentice
  Oil Leak markbob@ameritech.net 13 8,316 07-01-13, 03:00 PM
  Small coolant leak Avenger 2 3,171 04-07-13, 01:04 AM
10 Guest(s)
