Rear-end Re-fresh
#31
(09-12-25, 05:49 PM)theman440 Wrote: I need some opinions here, I bought these ball joints a while ago and just now got around to comparing them to the old ones. Check out the dome on top of the ball joint, the old one is flat. I dont think I've ever seen that before. They are identical except for that, my question is . . . do you think I will have intererence issues with the tire or rim?
With 14" spare that clears the 10.95" rotors
If you ever wonder where a 14" rim will hit on a 11.75 rotor setup and Wilwoods, here ya go.
(09-12-25, 10:43 PM)67440Dodge Wrote: I remember pulling those type ball joints when I worked at Kanters..  Forgot who made them, they weren't the cheap Indian made knock offs (China was too pricey for them back then).
Did you know up until about 10yrs ago the upper ball joint used in almost every oval track car from a Modified all the way to top tier Winston/Nextel/whoever now Cup was a B-body screw in?  I couldn't believe it when I saw it on the Monte Carlo we got from Darrell Waltrip in mid 90's, then 10yrs later on another car we got when we went Busch North
These are TRW ball joints.
Andy,
I'm not concered with the quality of these joints. They are Made in the USA TRW's
Upper control arms ready for new bushings, ball joints & the proper color paint!
[Image: img_1832-jpg.1918688]
Very nice.
Upper a-arms ready!
[Image: img_1833-jpg.1926184]
[Image: img_1862-jpg.1926186]
Time to modify the lower control arms - Im upgrading to a bigger swat bar. Need different style link brackets.
[Image: img_1857-jpg.1926198]
[Image: img_1860-jpg.1926200]
[Image: img_1861-jpg.1926201]
Got the brackets(s) from Hotchkis -
[Image: img_1859-jpg.1926202]
Nice!
More cleaning - dust shields, I was surprised to see they were galvanized. Not a spec of rust on them after 52 years, they were very dirty though. You can also see it the pic that they have that wrecking yard yellow paint pen writing on them . . . apparently these came off a '73 Satellite. My dad converted this car to disc brakes sometime between 1976 & 1980 - I believe he may have been one of the very first people to do this. At that time he had easy access to the parts because he managed a wrecking yard. It was called Thomas Auto Wreckers, located in Duarte Calfornia. Any of you SoCal guys know the place? No doubt he got the set up off a wrecked car from the yard.
[Image: img_1863-jpg.1926974]
[Image: img_1864-jpg.1926975]
That would have been sweet job working at a wrecking yard back then, all the cool stuff you see.
On the weekends that was usually our first priority was to hit up some yards, mostly in Colorado where we lived. Mopar stuff everywhere.
I remember going there in the Summers when I was a kid. So much fun exploring yard, I learned so much about cars hanging out there.
I did same in 03, got lucky and found a Dart going thru wrecking yard first time.  They were beat up and oxidized like aluminum, but no rust. worked good for almost 20+yrs.  Now you can't do it here anymore, have to go across to PA to scrounge around.
I like that weld in shock mount sway bar bracket, mine is just bolt on but  hasn't moved even though I thrash it at times.  The rear I had to weld to axle tube on right side cause it only contacts a small amount and kept rotating.
  convertible rear seat trim bike_guy123 3 25,606 06-30-18, 07:17 PM
Last Post: bike_guy123
  1966 Coronet 500 rear leaf springs richardmay2 3 13,427 07-18-17, 01:30 PM
  Some Rear Driveline Restoration... TX67RT 15 9,954 10-30-15, 01:06 PM
  Rear qtr window VERTICAL chrome trim seals..and Something I'm calling channel rubber.. TekHousE 8 5,847 09-03-15, 11:31 PM
  Need some help with rear molding? Warhawkfight34 2 3,529 11-19-13, 02:21 PM
  1969 rear window trim? Warhawkfight34 1 3,195 10-31-13, 08:42 PM
Last Post: rip
  Rear quarter extension question? Warhawkfight34 3 4,678 07-31-13, 04:24 PM
