Rear-end Re-fresh
Weldin is cheatin.. ya gotta beat em out like they were meant to be beaten...
(09-05-25, 10:49 PM)67440Dodge Wrote: Weldin is cheatin.. ya gotta beat em out like they were meant to be beaten...
Geeze Mike I recommend you go back to anger management classes.
(09-06-25, 06:49 PM)67r/t4speeder Wrote: Geeze Mike I recommend you go back to anger management classes.
I am taking them.. I didn't throw the brake rotor across the garage when the bearing race didn't fit like I normally would!!
Mike,
That was the method previously used to remove them. I have done it that was before but this time I wanted to use a little less brutality. It always creates more work.
Was kidding Jeff.. if I had a big enough vice/press, I'd have done same, lot less aggravation
I need some opinions here, I bought these ball joints a while ago and just now got around to comparing them to the old ones. Check out the dome on top of the ball joint, the old one is flat. I dont think I've ever seen that before. They are identical except for that, my question is . . . do you think I will have intererence issues with the tire or rim?
(09-12-25, 05:49 PM)theman440 Wrote: I need some opinions here, I bought these ball joints a while ago and just now got around to comparing them to the old ones. Check out the dome on top of the ball joint, the old one is flat. I dont think I've ever seen that before. They are identical except for that, my question is . . . do you think I will have intererence issues with the tire or rim?
Gonna depend on rim size, tire size and backspacing..  this is a 255/60/15 on a 15X7 rim with 4 1/2' BS.  Suspension is compressed but even with that big tire on front looks like it should fit.
The car has 14x7's with 245/60's on it. Dont know about the offset. I'guess 4.25
My brain would say red flag flying those ball joints are universal.
I would not use them.
I bought some Moog ones on sale recently if you need them. I just bought for back up.
I remember pulling those type ball joints when I worked at Kanters.. Forgot who made them, they weren't the cheap Indian made knock offs (China was too pricey for them back then).
Did you know up until about 10yrs ago the upper ball joint used in almost every oval track car from a Modified all the way to top tier Winston/Nextel/whoever now Cup was a B-body screw in? I couldn't believe it when I saw it on the Monte Carlo we got from Darrell Waltrip in mid 90's, then 10yrs later on another car we got when we went Busch North
  convertible rear seat trim bike_guy123 3 25,606 06-30-18, 07:17 PM
Last Post: bike_guy123
  1966 Coronet 500 rear leaf springs richardmay2 3 13,427 07-18-17, 01:30 PM
  Some Rear Driveline Restoration... TX67RT 15 9,954 10-30-15, 01:06 PM
  Rear qtr window VERTICAL chrome trim seals..and Something I'm calling channel rubber.. TekHousE 8 5,847 09-03-15, 11:31 PM
  Need some help with rear molding? Warhawkfight34 2 3,529 11-19-13, 02:21 PM
  1969 rear window trim? Warhawkfight34 1 3,195 10-31-13, 08:42 PM
Last Post: rip
  Rear quarter extension question? Warhawkfight34 3 4,678 07-31-13, 04:24 PM
