Coil over rear shocks for B bodies?
Who sells one? Need to lift the rear of my '67. Any other suggestions are welcome. Pulled out the air shocks based on the ride quality. This is a cruiser not a racer. Thanks.
Get the springs re-arched or buy new ones. Coil over shocks will eventually destroy the upper shock mount. It's not designed to carry a load.
theman440 Wrote:Get the springs re-arched or buy new ones. Coil over shocks will eventually destroy the upper shock mount. It's not designed to carry a load.
X2
X3
It's unanimous, okay thanks. Does anyone sell new leaf springs?
I’ve ordered leaf springs from springsnthings.com and was happy with them
65rbdodge Wrote:I’ve ordered leaf springs from springsnthings.com and was happy with them
X2 .. they'll even rearch em to give the car the rake you want
Thanks!
Late to chime in but I wouldn’t let that area support the weight of the car. Way to flimsy
  Rear air suspension PSI? OldSkool 8 5,193 06-29-15, 03:40 PM
Last Post: 68 500
  Rear Seat Belts installed OldSkool 5 4,404 06-16-15, 11:54 AM
Last Post: OldSkool
  Shortened my first rear markz 7 4,431 03-30-15, 12:09 PM
  Rear sway bar install honcho 5 4,698 12-14-14, 05:52 PM
  1967 R/T rear brake drum hemibro 12 8,046 11-26-14, 09:47 PM
  Rear package tray installed OldSkool 9 4,988 11-19-14, 03:42 PM
  Rear air suspension? OldSkool 1 2,490 10-25-14, 05:54 PM
Last Post: Drag-Net
  Maintenance day and what's the trick to getting the rear seat out? OldSkool 3 2,849 09-27-14, 06:03 PM
  Rear Deck Cover OldSkool 4 3,024 08-26-14, 12:50 PM
Last Post: OldSkool
4 Guest(s)
