Progress on my 67 Coronet R/T
theman440 Wrote:Wow, moving right along!
I started as soon as it started warming up this spring. Try to get a little done every day. Unfortunately, I smashed my finger at work yesterday so I won't be doing much for a week at least. Just got
a new trunk floor from AMD and scored an outer wheel housing from a donor car so I have plenty to do when I can.
If it ain't broke, fix it 'til it is...
Lots of credit man! That's a lot of fab work! But glad another blue R/T will see the road again!!
Nice work! Looks good
Save a lot of money doing bodywork youself!
The front corner of the trunk extension was rusty. Made another patch from the aftermarket piece. Trying to keep the good original metal. There was a part number stamped on it so I made sure to save that.
8514]8513]8511]8512]
I had never used a needle scaler before. Bought one to remove the undercoating. Works great! taking a wire wheel to it after that.
8517]8518]8515]8516]
I'm enjoying your updates thanks for posting.
Damn, you make it look so easy. That's some talent there.
Mark's 69 Wrote:Damn, you make it look so easy. That's some talent there.
Yes he is!!
What you're not seeing is all the cussing, looking for the tool I just had in my hand, and throwing things. That's where most of my time is actually spent!
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,045 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,483 10-15-21, 07:38 AM
  1967 Coronet Headlight surround fastners firepower 4 2,300 07-10-21, 12:39 AM
  '55 coronet vent window u channel rubber dodge55 1 17,807 11-27-17, 12:03 PM
Last Post: dodge55
  1966 Coronet 500 rear leaf springs richardmay2 3 13,426 07-18-17, 01:30 PM
  Pentastar location on passenger fender 1967 Dodge Coronet R/T chargerman71 3 4,936 06-22-17, 12:37 AM
  Started my 69 coronet 500 convertible resto. It is a factory 383 4 speed with air.. 69rag500 29 18,355 12-02-16, 11:14 PM
  67 Coronet grey/silver strips top and bottom of grill RT K_line 9 7,236 11-29-16, 12:18 PM
Last Post: don99pablo
  67 Coronet instrument cluster - turn signal and high beam and oil lenses! TekHousE 5 5,799 11-29-16, 12:18 PM
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
