'67 Factory tach and wiring questions.
My dad has a factory tach and harness he rounded up years ago. Thing is the harness that came with it is out of a manual transmission. (No gear lamp or reverse lamp switch) Can that harness be modified to work on an automatic car? Most of the wires in the tach connector are similar but I'm wondering if the whole console harness is different as well? This is a correct 4 wire tach as well.
To further describe the harness we have there is a piece that plugs in at the kick panel and runs to the center console. There is then another short piece that plugs into that and has the console lamps,gear and reverse lamp wiring.
Also is there a way to test a 4 wire tach before going through all this in the first place? Seen where you can do the battery trick on a 3 wire tach.
If you used page 8-110 in the manual there is a diagram that will help you with the rewiring
  Suspension questions Piper 10 41 06-06-25, 01:43 PM
  Best wiring replacement Dionisio -C- 28 13,988 06-07-17, 12:51 AM
Last Post: Dionisio -C-
  Recalibrate a factory console tach? 67RTBlue 1 3,217 03-19-17, 05:45 PM
  Turn Signal Wiring markz 5 5,795 10-12-16, 11:25 AM
Last Post: crlush
  Speedo Gear install and questions-727 67RTBlue 5 5,258 09-12-16, 11:02 AM
Last Post: RT K_line
  Fan Switch and Other Wiring scottys67 13 8,142 08-29-16, 12:11 AM
Last Post: scottys67
  440 build questions. Intake,carb,torque converter? 67RTBlue 18 10,881 06-12-16, 11:24 PM
Last Post: BBishere2
  Is the firewall different on a factory power brake car? 67RTBlue 2 3,379 04-07-16, 07:57 PM
