Quick shift trans fluid
I remeber a long time ago hearing that using ford trand fluid would make the car have more positive shifts . Also companys like B&M claim the same thing . Does anyone have any experince with this ? Thanks . BooBoo
BooBoo Wrote:I remeber a long time ago hearing that using ford trand fluid would make the car have more positive shifts . Also companys like B&M claim the same thing . Does anyone have any experince with this ? Thanks . BooBoo
Hi BooBoo,
I've run the Ford style transmission fluid in my 66 Coronet 500's high performance full manual shifted 727 Torqueflite automatic transmission since 1990 or 1991 when I installed the transmission. I've also used the Ford fluid in several other high performance Mopars I've owned over the years with modified automatics. If your transmission is completely stock, I doubt that the ford trans fluid will do much for you, but if you're running a heavily modified transmission like I am, the Ford fluid will handle higher transmission temps under high performance use, or towing heavy loads better. The three things that will give you more defined shifts, are a shift kit, a more performance orientated torque converter and a deep transmission oil pan that will hold additional transmission fluid to help transmission cooling under heavy use.
My take is this, Ford TYPE F trans fluid has more/different friction modifiers than GM DEXRON. It's the friction modifiers that make the difference in shifting. Mopar ATF+4 is in my opinion the best at handling extreme heat, it's what I use in my Coronet. I don't like ATF+4 in the winter in a daily driver though as the fluid doesn't work well cold.
  My column shift is out of sync pistolero5150 4 808 10-31-22, 12:19 PM
  Trans leaking like a sieve after parked-couple other leaks. 67RTBlue 12 7,985 08-22-17, 08:08 AM
Last Post: crlush
  slant 6 to overdrive trans adapter RT K_line 7 4,749 12-12-15, 01:13 AM
  Small annoying issue with my Floor shifter - 727 Trans TekHousE 6 3,401 09-02-15, 04:07 AM
Last Post: TekHousE
  Motor Home Trans mike1968rt 9 5,786 03-06-14, 01:52 PM
  Automatic: column shift, gear selector lighting. 1967 Coronet 500, 2 door, Hard top. Hibbing_Coronet_500 12 7,831 04-03-13, 02:17 PM
  how to you convert a column shift car to a console car??? joshua 7 5,759 03-17-13, 03:18 PM
Last Post: joshua
