Threads: 43
Another funny question.. How to keep it upright in the trashcan? Lol
Threads: 8
Douse it with Viagra?
Threads: 5
Most old time shops and or car guys have an old 120 lb grease barrel that has been repurposed as a garbage can. These work best. This was from back in the dark ages when cars used to be equipped with grease fittings. Be prepared fo all of the trans oil to come out of the tailshaft!
Threads: 43
I just saw on rock auto an oil pump repair sleeve.. Whats that? And idk if i have a place to sit it upright.. How do you tighten the front band?
Threads: 57
Avenger Wrote:I just saw on rock auto an oil pump repair sleeve.. Whats that? And idk if i have a place to sit it upright.. How do you tighten the front band?
the way that I`ve always tightened the front band is to loosen the lock nut, finger tighten(I think the spec is 14 inch pounds, can anyone confirm?) it and tighten the lock nut making sure you don't tighten the band any more. the band adjuster if I remember right is just above or close to the fitting of the front trans line on the outside of the trans.
Threads: 5
The bands are adjusted by torqueing the adjuster then backing it off a specified # of turns(varies with application), then locking the lock nut. The front band is adjusted externally and the rear is accessed by dropping the pan.
Threads: 57
Sedanman67 Wrote:The bands are adjusted by torqueing the adjuster then backing it off a specified # of turns(varies with application), then locking the lock nut. The front band is adjusted externally and the rear is accessed by dropping the pan.
that's right! now I remember, I do have some cobwebs in my head.
Threads: 43
This is how you put the top bolts in.. Lol
Threads: 8
I applaud your mechanical stick-to-it-iveness!! Gettin' down and dirty, body in the engine bay stuff!!
Threads: 154
