Threads: 57
what I do that works every time is put the closed end of the wrench on the bolt, put 2 fingers over the closed end/bolt head to hold the wrench in place and hit the open end with a 5lb hammer to turn it. the motor must be held from turning or this won't work. usually a long screw driver shoved up in the flexplate some where keeps it from turning.
Threads: 43
with the little time i had tonight....The flexplate bolts are out..nothing that the 1 1/4 socket (that i just got) holding the engine still and a rubber hammer couldnt solve... lol its ready to drop....thats next time
which is gonna be soon lol
-John
Threads: 57
good to hear you got the bolts out, I`ve been wondering how your project has been going.
Threads: 43
I hope it keeps going..i may be able to have time to drop it tonight..fingers crossed
-John
Threads: 43
So as usual anytime i work on anything i run into a million problems... I cant get the cross member out.. The exhaust pipes are in the way.. Easy way to weasle it out or one pipe has to be unhooked?
Do you have a cross over? If so you will have to lower both sides. Otherwise could you lower the back enough? Do what ever seems easiest.
Threads: 43
Well its lowered... i dont know what wrong with it yet because i was too tired to mess with it anymore lol.. ill have to find a way to work on it under there or weasel it out from underneath the car..but sweet success for now
-John
Threads: 8
Looks like you have the chassis up high enough to wrestle that monster out of there.
Threads: 43
The most fun part was sitting on top of the engine getting the top bolts... lol..
-John
Threads: 8
Then there are the dowel pins to back off from. Yah, I hear 'ya. Getting down and dirty in your engine bay to get those bolts out gives a whole new meaning to 'getting personal' with your ride! How are your knuckles fairing?
