ALUMINUM VALVE COVER LEAKS
markz Wrote:I am a big fan of aluminum valve covers. Properly fit with a good gasket they are hands down the best.
Big issue I have found with many (but not all) is that the boss where the bolts go through is too high for a cast head and the sealing rail never compresses the gasket. One way to test for it is to install your cover with gasket but put strips of paper between the gasket and head (in the places it leaks). If it pulls out easily, you don't have proper sealing pressure.
On most (if not all) of my aluminum covers I have used over the years I have had to machine the bosses down - typically around 0.080". Worked like a charm with Felpro rubber gaskets. Glue one side to the cover with RTV (glue the gasket to the cover then put cover on a flat surface with weight on the cover till it dries - typically overnight). This way you can pull the covers off many times and the gasket reseals well if all is clean.
On the race car I o-ringed the covers because I take them off so much.
2065
Markz, how you doin', long time haven't heard from you, you finally found the new site?
Anyone use cometic gaskets?
Racer Brown Wrote:Markz, how you doin', long time haven't heard from you, you finally found the new site?
Yeah - was trying to figure out why my login wouldn't work! LOL!
Been super busy. At airport getting in from Beijing and off to Poland on Sunday! Work/travel has been insane last couple of years, but it does well paying the bills........
I will do a catch-up post on my Coronet adventures, but the short rundown is the race car is at John Holt's shop getting an Alterkation front end installed and general go through of the car. Car spins and won't wheel stand with the new M/T tires, but is very consistent. He will hopefully get the car set up to wheel stand again and hook better. Car slowed a solid tenth in the quarter with the new tires. I'm hoping for 9.50's (in the 1/4) with the new setup.
Daughter's street car got the old race car 440 in it now (severely detuned), and has been nothing but problems since. Mostly exhaust (massive case of reversion with stock manifolds) but mostly fuel problems both with mechanical and electric pump. Now believe my Aeromotive electric pump was bad (iwas not relieving - 29 psi was supposed to be 14) and they have it for repair. It went 14.61 at 92 a few weeks ago, but with the headers I am hoping for at least a 3/4 second improvement maybe as much as a second.
Update on my leaks.i finally took Richards advice and picked up a set of the stamped steel valve covers and no leaks!motor looks good too.thanks Richard.david
Good to hear, thanks for the update!
383bee Wrote:Update on my leaks.i finally took Richards advice and picked up a set of the stamped steel valve covers and no leaks!motor looks good too.thanks Richard.david
Hello David,
VERY cool to hear that you were able to fix your leaking issue! The new stamped steel Direct Connection chrome valve covers look GREAT as does the rest of your engine compartment! Cool Some day down the road if you get tired of trying to keep your natural aluminum intake manifold clean, you might consider painting it to match the rest of the engine and that will be one less thing to worry about also! Wink
I enlarged your picture so everyone can see it easier!
2288&d=1373225215[/IMG]
Here's the 440 in my 66 Coronet 500 with a painted Edelbrock Torker intake manifold.
[Image: My1966Coronet500-5-23-2013-5.jpg]
Those painted aluminum intakes always look nicer than the bare aluminum, imho. The natural aluminum tends to get corroded by all the elements present in an engine compartment, including the extreme heat. The factory aluminum 2 x 4 HEMI intakes were painted as well. I prefer them painted but each to his won.
I am not alone liking the painted manifolds I see.
2293&d=1369588055[/IMG]
you guys have some nice looking engine compartments.i wish the po would have gone the extra step and not painted mine black.i like the clean look.
Since that pic of mine I have replace the water pump housing with a stock one and painted it engine color.
How do you like your radiator? Who makes it?
  Trans leaking like a sieve after parked-couple other leaks. 67RTBlue 12 7,985 08-22-17, 08:08 AM
Last Post: crlush
  M/T valve covers 65rbdodge 8 6,980 09-07-16, 08:15 AM
  Aluminum intakes-washers on bolts and torque specs? 67RTBlue 3 3,010 03-02-16, 09:59 PM
Last Post: tgranthamfd
  Aluminum Bellhousing 67440Dodge 5 5,544 07-18-14, 08:29 PM
Last Post: 4264door
