Mopars & Missiles' Wrote:Have you inspected the sealing surface of the head in the area of the leak? You may have some sort of defect there that is causing the leak.
Also, use a straightedge to verify the sealing surface of the head is flat.
It's also possible that the aluminum cover has some porosity in that area and is seeping oil.  A close inspection of the cover in that area might reveal the problem also.
Mopars & Missiles,
I totally agree with everything you've said! The original cast iron cylinder heads that many of us are using are now over 40 years old and after seeing so many heat cycles, warped mating surfaces can easily happen and most folks don't have their machine shops check their cylinder head to valve cover mating surfaces for flatness, which can be a very annoying mistake throughout the life span of their engines due to difficult to fix leaks. .
383bee,
Here's an interesting read from the Dodge Charger web site that speaks about the identical issue that you're having with the passenger side rear corner of the Mopar Performance cast aluminum valve cover leaking and possible causes and cures.
http://www.dodgecharger.com/forum/index....ic=69822.0
I've never been a big fan of the cast aluminum valve covers produced by anybody, because they don't have any of the flexibility that the stamped steel valve coves offer. I've been using the original style Direct Connection chromed stamped steel valve coves on all of my big and small block powered Mopars for years and have had very few issues with them. The originals are getting harder to find, but Mopar Performance is now reproducing a modern version of these valve covers using all new tooling under part #P4349633AB and they can be purchased at a very reasonable price as seen in the information and web link below, so those covers along with a good set of valve cover gaskets would be my suggestion to solving your valve cover leaking issues.
![[Image: 978_1189599894.jpg&w=235]](http://www.moparsupercenter.com/images/products/thumb.php?img=1/978_1189599894.jpg&w=235) Description
                     Description
                     New "Direct Connection" Chrome Valve Covers For  Big Block Mopar Engines. These Covers are just like the originals from  the 1970's and are chrome plated with baffles and grommets.The "Direct  Connection" valve covers will add that perfect retro touch for any  361,383,400,413,426w or 440!
Full Description
                     Stamped from brand new tooling to ensure superior valve cover sealing around the cylinder head.
High luster chrme finish with vintage "Direct Connection" logo.
Package includes two chrome valve covers with built in baffles and rubber grommets.
Online Price: $59.91
 Web site link:
http://www.moparsupercenter.com/mopar-pe...633ab.html
