Rear gear ratio
thanks for the tips guys.booboo to answer your question i am going to make sure my whole set up is tuned well before i go into the rear gears.i'm a little new to really looking into the whole set up on a car.the motor and trans had 450 miles on rebuild when i got the car and what i have been able to find out about the motor is pretty basic.30 over flat top pistons comp cam 280h grind.comp springs.hp exhaust manifolds,600 cfm holley.727 2000 stall.only things i have done is put a eddy performer intake on and a 750 vs carb.upgraded plug wires and a few elec things.trans wont downshift so i'm getting that taken care of then i will have the timing and carb tune looked at before i move into any gear work on the rear.do you guys see any glaring probs so far?motor runs well i just want a little more umph thanks again,david
if i want to look at changing out converter what would you recommend?
  Rear Wheel/Tire Size Advice MrV8JF 1 225 05-15-23, 09:36 AM
Last Post: revel68
Last Post: RT K_line
  Band Lever ratio tgranthamfd 2 3,324 04-01-16, 12:10 PM
Last Post: Sedanman67
Last Post: Dionisio -C-
