1966 Coronet Engine and Tranny choices Advice
PUT A 440 IN IT AND HAVE FUN. my coronet came with the 318 poly 3 speed on the tree. I changed over to a 440 with 727. reused the existing tranny mount, drive shaft and the k frame. I also reuse the standard 440 motor mounts that you can buy at Auto zone or Advance. I did change out the rear it came with a 8 3/4" but I added the #9 housing. All the front suspendion is the same just new.
and I run 11's in the 1/4
  67 coronet window fuzzies D1esel 2 11 03-24-25, 09:07 AM
Last Post: D1esel
Last Post: Krooser
  Rear Wheel/Tire Size Advice MrV8JF 1 225 05-15-23, 09:36 AM
Last Post: revel68
Last Post: dag1969
Last Post: R/T XTC
Last Post: Just Wheels
