Threads: 473
67RTBlue Wrote:Seems like it should hold each gear a little longer. It rolls through all 3 by the time I hit 20 under light throttle! Would shortening the rod a little extend the wind-out in each gear?
Longer , you need lever on trans. to pull back little more. Just make sure you have full throttle and not bottoming out lever after done.
Threads: 79
The tranny literally hits 2nd by 10mph even under medium throttle. What's the deal there?
I tried shortening the rod by 3 turns and it really didn't do anything. I then turned it back to the "book" setting and went one more turn which would be slightly longer. When I apply full throttle the lever on the trans is also reaching maximum rearward movement. I would like to get the gears to "stretch out" a little more before going into the next gear.
Threads: 2
