Threads: 49
Theres no power going to the plug for the blower motor. Is there a relay some where for it . I took the fuse panal out to look at the back of it . Theres a fuse that dont have any power on either side and there are 2 emply spayed type connectors with no power to them either . The checks were done with the key on . Also on another note that may be linked to this problem , the gas gage and temp gage dont work either . There wasnt a wire going to the temp gage but there is now . I havnt checked these gages , I'm just starting with the heater problem first . Thanks . BooBoo
Threads: 477
Check for power at the fan switch next
Threads: 49
Dont know why I didnt think of that . Theres power there . So I reconnected the switch and if your gentle with the switch it works OK now , didnt have nothing before . Some times the speeds dont seem to work right , so i,m guess its the switch needs replaced . Thanks for your help . BooBoo
Threads: 11
I had a problem with mine a while back.It only worked on high.The switch was bad.
