04-28-15, 03:36 AM
I am stripping down my 1976 360 engine (first time), and I am stuck - literally. I've got all 12 bolts out, 6 per side, and everything else is off the manifold. The thing won't budge. I've tried a mallet, hitting with a hammer with a wood block in between, soaked it in PB Blaster, and tried to go around with a putty knife. I can get the putty knife completely in on the front side, but the gasket in all other sides is like the block and manifold are welded together. Any ideas would be greatly appreciated - I'm getting close to giving it up.
On a side note - I tried to take off the distributor to get a better view of the rear of the manifold, and I basically took everything apart and still couldn't get the distributor off the shaft. Haynes manual said to remove a screw and pull up - my so much. Anyone have some advice?
