Threads: 482
thebankerstoy Wrote:What are the specs on the new cam Andy"
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Threads: 208
67r/t4speeder Wrote:Advertised Duration (Int/Exh): 268/276
LSA/ICL: 110/106
Looks to be a nice cam, but it is a hydraulic design, so even though you're using the Valvoline Racing Motor Oil Andy, I'd still highly recommend using something like the Comp Cams part #159 "Engine Break-In Oil Additive" which is rich in ZDDP (zinc) and continue to use it at every oil change along with your Vavoline to protect that new cam and lifters my friend.
I'm running one of the Mopar Performance 6 quart Hemi oil pans on my Coronet's 440, so I use one full 12 ounce bottle of the Comp Cams oil additive along with the Chevron Delo 400 motor oil. I also use this same motor oil and oil additive in the 318 in my sons Dart and it's worked out very well on both cars.
Threads: 482
Thanks Richard I will.
Maybe someday I can swing a roller cam now but this will do for now.
Threads: 208
67r/t4speeder Wrote:Thanks Richard I will.
I sure understand that Andy, as the roller camshaft and lifter set-ups do hit you squarely in the wallet up front, but with the excellent maintenance that you give all of your cars and trucks, a roller cam and lifters would live a long happy life in Max and the issues that you've experienced with a hydraulic cam and lifters would be just a bad memory.
Another option that I'd like to learn a whole lot more about, are the roller hydraulic lifters similar to the ones offered by Howards Cams below and sold by Summit Racing. Lots of other cam manufactures make these also, so the Howards are just used as an example.
Summit Racing link:
http://www.summitracing.com/parts/hrs-91767/overview/
Quote:Howards Cams Street series retrofit hydraulic roller lifters are designed for street performance enthusiasts who want to upgrade to a hydraulic roller camshaft. They are manufactured to fit early or late model blocks, including blocks with tall lifter bosses. Howards Cams uses cold form technology to shape their bodies for durability. The lifters are then carbonitrided and tempered for hardness. They also feature hardened and tempered steel alloy roller wheels, heat-treated stainless steel cross bars, and high-alloy steel tie bar buttons. Howards Cams Street series retrofit hydraulic roller lifters are made in the USA and are specifically designed for street applications up to 6,500 rpm.
![[Image: HRS-91767_xl.jpg?rep=False]](http://static.summitracing.com/global/images/prod/xlarge/HRS-91767_xl.jpg?rep=False)
Maybe some of our members who have purchased and run these style of lifters could let us know what they think? Are these style lifters also compatible with all hydraulic camshafts?
Threads: 482
I have built two383 stroker chevy engines with those and they love it. I get more people wanting me to build them one but gulp at the price but good parts cost.
My440 I am starting on for Max will be roller
Threads: 208
67r/t4speeder Wrote:I have built two383 stroker chevy engines with those and they love it. I get more people wanting me to build them one but gulp at the price but good parts cost.
Do you know if those style roller hydraulic lifters will work with any hydraulic camshaft Andy, or do they require a specialized cam?
Threads: 482
06-24-13, 11:26 PM
(This post was last modified: 06-24-13, 11:38 PM by 67r/t4speeder.)
Always matched cam and lifters my machinist has. First set were Comps, good but noisy
, other was crower and no noise ran same though.
Threads: 29
Did the MAD electrical ammeter bypass and installed relays for the headlights. One question: can humidity shrink cars? Because I don't remember having that much trouble fitting under the dash before!
Mark
Threads: 312
thebankerstoy Wrote:Do you know if those style roller hydraulic lifters will work with any hydraulic camshaft Andy, or do they require a specialized cam?
When you run a roller lifter, you have to run a cam that is ground for them. Otherwise they'll do nasty things to each other..
Threads: 482
Mark's 69 Wrote:Did the MAD electrical ammeter bypass and installed relays for the headlights. One question: can humidity shrink cars? Because I don't remember having that much trouble fitting under the dash before!
Mark
