Threads: 2
Please please please don't use a stick welder. Borrow a wire feed if neccesary for better control or you'll warp your panels so bad you will have to replace them. Even brazing with oxy-acetylene is a better option than arc welding.
Threads: 8
+1!!!
Threads: 11
Sounds like I need a Fathers day present for myself from Sears. Thanks
Threads: 58
Wire feed welders have come down in price. I'd buy a machine that has gas capabilities or stick with the non gas flux core wire. Gas gives cleaner results over flux core.
I got my Hobart 140 with gas attachment for less than $500.
Threads: 597
please you a MIG WELDER on the quarters and not stick weld it .....
