Lower quarter panel
1929The lower quarter panel behind rear tires rusted. I cannot find any lower replacement panels. Looking at the 72 Charger replacement lower rear quarter panel they look almost the same shape. Would that work? Or does anyone know where I can get the patch panels. I've looked at all the usual places and e bay.
http://wilmington.craigslist.org/pts/3810990890.html
Would this work. Any opinions
would have to call to see if its for a 2 dr or 4 dr .....
and not a bad price to pass up esp. for a pair .....
The only thing the quarter panels in the CL ad have in common with his car is the year.
Hey Coronet14, I'm in a similar situation, but your quarters look almost too good to replace! I would try and patch up the ones you have... I've got a '71 4 door and was looking at the Charger patch panels, as well. I found the measurements on the amd website, and the Charger panel is a few inches shorter than the same measurement on our Coronets, all of it from the back end of the wheel arch to where it meets up with the rear valance panel.
Seriously, I wish mine looked as good as yours!
The left lower quarter is rusted and bent. I can try and fix it trying to decide what would be easier. The right side has filler and bubbles under the paint along with the rust hole. I'm gonna have to take it all down to metal to see how bad it is. I'll put up some pics. 19441945194619471948
those dont look bad at all ...... its repairable, i would say ...
I would also say that those are repairable too. Get some 16 or 18 ga sheet stock. A way to cut it. A way to shape it. Cut out old crap and wire feed weld in your patches. Grind and fill. Prime and paint.
I've got a stick welder haven't used in years. I'm gonna start practicing before I start on panels. I'm going to try to save them. Thanks
  Anyone doing ´67 chrome trunk panel reproductions? Irores 6 24,420 03-26-19, 12:42 PM
Last Post: Irores
  1970 Tail Finish Panel Hardware Piscataway Pete 1 16,508 03-16-19, 08:50 AM
  Painting chrome-taillights & finish panel 67RTBlue 18 13,648 11-02-16, 08:21 PM
Last Post: Red 67
  Coronet sail panel chrome help needed RT K_line 3 5,403 07-12-16, 07:22 PM
  67-R-T-Trunk-Panel smhemi 4 4,745 01-31-16, 08:18 PM
Last Post: smhemi
  67 500 badge on trunk panel paint codes mocam8 3 4,336 06-09-15, 01:32 PM
  Trick to install the dreaded lower dash bezels Billb66 0 3,163 02-26-15, 04:24 PM
Last Post: Billb66
  Rear quarter extension question? Warhawkfight34 3 4,678 07-31-13, 04:24 PM
  Replacing panel with gas tank door on it cnmsales 14 8,181 03-10-13, 11:05 PM
Last Post: cnmsales
