On my 68 Charger which was a power drum car all around I've upgraded to a 7/8 bore Wilwood master and SSBC discs up front.
I am trying to bleed the fronts now for days with no luck (backs bleed fine). I am getting fluid into the distribution block from the master but cant get it to come out the other side of the block for the fronts. Do I need to change the block (if so to what) or could it be a matter of a stubborn air pocket?
That is the same one I have. End port opposite the plugged end is front brake and bottom two by plug are for rear brake. sounds like you have that part correct.
Are the ports marked which is front and rear on new wilwood?
Looks like your front brake line should go to further out away from firewall A outlet and B to rear, which is opposite from Mopar master ( at lest mine anyway)
67r/t4speeder Wrote:That is the same one I have. End port opposite the plugged end is front brake and bottom two by plug are for rear brake. sounds like you have that part correct.
The ports arent marked
I just checked this on my 67 Coronet and its the same
The top line (at 12 o clock position) is coming in from the rear port of master, the bottom right plug is coming from the front port
