Restored and installed the original brake lines, clips and proportional valves. Also restored and installed the parking brake. Would have installed the fuel line but I welded a hole in it fixing the floorboard before it removed it... duh...
9257]9258]9259]9260]9261]9262]9263]9264]9265]9266]9267]9268]
Jim I have been there done that with restoring those original lines and you have done an excellent job, I appreciate all that hard work you have done. Keep it up.
Do you have suggestions on fixing the fuel line? I ended up with a weld droplet on the line that I tried to "scrape" off and it ripped a hole in the line. I could get a new one from Classic but I would rather have the original.
Just for fun here is where I started this spring and where I am today...
9269]9270]
How about a compression union
67r/t4speeder Wrote:How about a compression union
Ouch, a good stainless steel one is not cheap.... ~$15 then I need to rent the tools make the flares..... The replacement is looking better Smile
[Image: -font-b-Brass-b-font-Fit-font-b-15mm-b-f...dapter.jpg] Get a brass one at the auto parts store like this, they seal better than stainless. No need to flare anything. Would not use if fuel injected engine due to pressure.
67r/t4speeder Wrote:Get a brass one at the auto parts store like this, they seal better than stainless. No need to flare anything. Would not use if fuel injected engine due to pressure.
I thought about that but was not sure about the corrosion of dissimilar metals....
X2 on the brass union will work with no problem, nice job so far by the way.
Ok, I'll give it a shot.
5 Guest(s)
