Fiberglass (aftermarket) hood too flexible..
Man, I'm getting old... I think 75 is fast.Rofl
Those are pretty flimsy braces. Adding strategic bracing using foam would be pretty easy to do and should help quite a bit.
As long at the hood is properly secured flexing won't hurt the hood too much. I made a hood one time and was not smart enough to brace it. Talk about flexing.........
My AAR hood goes 140 mph but it has 8 hood pins.
Stargazer Wrote:About speed, due to the flimsy hood, I dare not go faster than 100 Mph.
Do any of you ever drive at high speeds? Say 125Mph?
I assume with the 383 or bigger engines it was possible to do when they left the factory?
Oh yes, it was very possible.
Back in the mid '70's when I was young and REALLY dumb (unlike now when I'm REALLY old but still dumb) I took my car up to 140 mph on a couple of occasions. 383 automatic car with 3.23 rear gears, all factory stock configuration. So yes, they will do those kinds of speeds, no problem.
ws27 Wrote:Man, I'm getting old... I think 75 is fast.Rofl
RoflBanging GearsRofl
markz Wrote:Those are pretty flimsy braces. Adding strategic bracing using foam would be pretty easy to do and should help quite a bit.
Ok so it can be done. And 140! Wow!
8 hoodpins, so you've got 4 more braces under there?
Mopars & Missiles' Wrote:Oh yes, it was very possible.
RoflRofl (still dumb)
Good to hear that these Muscle cars where capable of doing these kind of speeds! 140 must have been impressive for young guys, especially in those days.
Mine has 3.55 gears. Better or worse for top end speed?
Stargazer Wrote:Mine has 3.55 gears. Better or worse for top end speed?
That will give you LOWER top end speeds for the same given engine RPM.
Stargazer Wrote:Ok so it can be done. And 140! Wow!
8657]8658]
Mopars & Missiles' Wrote:That will give you LOWER top end speeds for the same given engine RPM.
Ok thanks!
markz Wrote:8657]8658]
Yes that looks very solid. Thanks for these pics!
  Metal RT hood odot365 0 2,985 08-14-16, 02:15 PM
Last Post: odot365
  1967 500 Hood latch? Smoke4570 13 7,010 12-11-15, 12:56 PM
  1967 coronet fiberglass front bumper Stage III 0 2,654 06-09-15, 07:43 PM
Last Post: Stage III
  hood hinges olebrowndodge 1 3,475 07-27-14, 09:16 PM
Last Post: Drag-Net
  1969 Hood Latch markbob@ameritech.net 0 2,723 05-14-13, 07:54 AM
Last Post: markbob@ameritech.net
  Aftermarket Shifter Zaq 2 4,403 01-13-13, 03:03 PM
