Axle swap.
My 72 has a 8 3/4 rearend, I have the stock rims from my 88 dodge pickup. They are the size I want to run on the rear, can I swap the axles from a truck 8 3/4 into my coronets rearend?
Your Coronet has 30 5/8 length axles stock.
Are you sure that `88 truck has a 8 3/4 rearend? They are more than likely different length.
I have not really checked, I was looking for a cheap way to run bigger rims. The other rearend is out of a 74 ramcharger.
  Axle bearings, seals, etc.. Coronet67500 2 12 01-24-25, 05:34 PM
Last Post: Coronet67500
  Rear axle wheel bearings Dionisio -C- 6 4,642 02-22-15, 08:07 PM
Last Post: Dionisio -C-
  rear axle coronet 69... o.dima 4 4,230 11-12-14, 06:44 PM
Last Post: o.dima
  440 swap Jmos68 9 6,112 03-09-14, 05:18 PM
Last Post: Jmos68
  Transmission swap question Avenger 9 8,031 08-21-13, 02:41 PM
Last Post: duke51
  Gauge Swap markbob@ameritech.net 1 2,984 06-21-13, 12:59 AM
  Rear axle bearing and retainer kits 67r/t4speeder 6 6,369 02-01-13, 07:44 PM
  inner axle seals Avenger 5 5,443 01-08-13, 11:40 PM
