inner axle seals
On an 8 3/4 what is the best wya to get the old seals out and get new ones in.i am finally able to fix it and am excited ahah
-John
[Image: IMG_1711.jpg]
Your local auto parts store should have available a seal removal tool for your application. The right tool makes the job easy and problem free.
what about putting them in?
-John
You should be able to easily pry the old seal out with a cats paw or something similar. Just be carful not to scratch the bore. to get the new ones in, just use the correct size 1/2 drive socket with an extension and it'll go right in. If you're as nuts as me, put a very thin amount of silicone on the outside of the seal and in the bore where the seal will end up.
Good luck.
Put grease on the lip spring of the new seal helps keep it from popping off while installing
All great ideas you guys rock
  Axle bearings, seals, etc.. Coronet1967 1 3 Yesterday, 11:09 AM
Last Post: Dionisio -C-
  rear axle coronet 69... o.dima 4 4,230 11-12-14, 06:44 PM
Last Post: o.dima
  Axle swap. Ledsled 75 2 3,952 02-16-13, 09:10 PM
Last Post: Ledsled 75
  727 Needs seals Hibbing_Coronet_500 7 6,618 02-16-13, 03:04 AM
  Rear axle bearing and retainer kits 67r/t4speeder 6 6,369 02-01-13, 07:44 PM
