.......and a new set of white wall tires? WOW Cool!!!
They look good with the hubcaps I think
I agree Andy and they will look even better against the Turbine Bronze exterior color!
7179] Had some time to work on Jr a little, there was a dent in middle just above wheel well.
I took picture ten feet away and on shade so so you can't tell if I did a good job or not.
We all know that not a drop of the Turbine Bronze paint will touch that quarter panel until it's perfect in your minds eye Andy. Wink
That's right. I expect to be sanding the Express for at least 3 months before thinking about paint. Long wide panels equals blocking.........I bet you did a great job on that dent.
Not too surprise that heater core started leaking on Jr but how it started leaking is different to me. I was driving home from work and I just set timing and wanted to do the load test to see if it would ping, well I got a whole lot more than a ping LOL . I had it kick down into second and Wow!! hang on OL JR was feeling his wheaties we were heading to the moon it felt like, these lil 340 get with the program. While I had an ear to ear Smile I heard a pop and a sudden familiar smell of hot coolant and look down and the floor is sprayed down with the green stuff. I made a run for home not far away and cleaned up the mess and ordered a core. Really easy to put in for an a/c car, being as the a/c box is separate from the heat box, MoPar guys were thinking thank you very much.
Have you seen a core exploded like this before? Looks like it may have been half plugged and pressure of me stomping on it made it pop!! And of coarse I found another mouse nest in there and up in the fresh air cowl. grrrrrrmachinegunekelly
7634]7635]
Shoot Andy, that heater core only lasted 48 years? Maybe it's still under warranty? Rofl
Regarding Jr and his 340, I know for a fact that many a big block powered muscle car fell victim to the 340 powered A-Body cars on the street back in the day! An A-Body car with a 340, 4 speed and a 3.91 gear ratio was a tough set up to beat from stop light to stop light! Banging Gears
thebankerstoy Wrote:Shoot Andy, that heater core only lasted 48 years? Maybe it's still under warranty? Rofl
Still haven't put a core in Max either(knock on wood)
I'm thinking it froze at some point. I've never seen a heater core do that either.
  The Max build = 1967 R/T 440 4-speed Dana-60 67r/t4speeder 337 122,112 05-16-25, 10:03 AM
