car won't start
#31
Well I do not think a its compression or valve issue..couldn't get to them all because of the headers but the ones i tried builds pressure and takes a long time to leak down..all around 200 to 210 psi
exhaust valve are doing their work...getting air blowing out of the plug hole
I'm off tommorrow. ..i am taking it all back apart and checking everything
That is good news
http://youtu.be/fz_sgbBbLXQ
the issue......re primed motor. ...lifters had no oil
thing is ferocious.
That's
why I asked if the lifters had been bled of air. I always do the same thing with new hydraulic lifters. I put them in a flat pan of fresh oil and push the plungers individually many times. Leave them over night completely covered in oil and do it again and you would be surprised how much air bleeds out of them. Do this a few more times, it is worth the effort. Glad to see you got 'er ferociously running!
WOOHOO!!
I've never had to bleed lifters. Don't they bleed them selves when you prime the motor?
this one had me baffled, I primed the motor last week so thought they would have been pumped up. I called Don @Crutchybilt and he said to prime the motor again, did that for a second time (sat on the drill this time for a solid 3 minutes) BAM fired right up.
They will but not for a few minutes assuming there is enough oil to start the engine inside of them, meanwhile the cam/lifter surface is clacking away and causing pre-mature wear on the lobes and the push rod to rocker arm contact points and the valves won't open/close at the proper specs. Make sure the oil you bleed them in is absolutely new clean fresh in a perfectly clean container because even a little speck of dirt can enter a lifter and gets lodged in a bleeder hole and plug the lifter. It also helps to heat the oil up somewhat to help the oil flow through those new lifters.
Good info thank you.
I did use the Brad Penn break in oil (zinc) hopefully that may have helped not wiping something out.
Piper Wrote:Good info thank you.
That's good oil, Kev!!
  fresh start R/T XTC 18 8,917 04-04-16, 08:57 PM
  Where do you start? Hemi Guy 8 4,892 06-03-13, 09:38 PM
Last Post: Hemi Guy
