Threads: 154
Have spark gas and timing is right on..won't start...
Using the accels because of the supercomps..the auto light is what I run in my 4 speed
think the plugs are the culprit? Consensus?
Thumbnail(s)
Threads: 154
Threads: 8
What are your plugs gapped at?
Threads: 154
.35
doing some googling, looks like the reach is just too short seems like Edelbrock calls for .750
I would have thought it would still start
Threads: 308
Yes..the plugs are not even close to the combustion chamber..
Threads: 10
How long has it been since you last had it running and have you done anything to it since then?
Threads: 154
[quote=JohnS]How long has it been since you last had it running and have you done anything to it since then?[/QUOTE
It is a new motor
Threads: 474
Calls for a RC-12YC plug
double check timing again just to be sure
Threads: 154
Danny called me this morning to talk through it, one of the thoughts he had was valve adjustment. They are roller rockers but hydraulic lifters. The way I adjusted them to 0 lash was when the exhaust was open set the intake & when the intake was closing set the exhaust
i then turned another quarter turn and locked them down
sound right?
Threads: 57
09-15-14, 07:58 AM
(This post was last modified: 09-15-14, 08:00 AM by 65rbdodge .)
I`ve always used the chart. and went 1/4 turn past 0 just like you.
http://www.moparts.org/Tech/Archive/motor/14.html
