Body work is progressing on the 69 R/T
Another
440 is progressing, got the cam and springs, Mopar Performance 284/284 duration 484/484 lift cam, should be fun behind the 4 speed and 354 Dana
67r/t4speeder Wrote:Especially with those twin turbos
Ditch the 273 and put a Poly in it.
Naw...itll be fun spanking Max a baby motor.. Smile
If you beat Max, then you can step up to the "Flying Brick"
I'll def need the twin turbo's then!
theman440 Wrote:If you beat Max, then you can step up to the "Flying Brick"
That is an appropriate name Jeff.
FINALLY - the first local car show & the weather was great! Actually got to drive the '66 with the window down & the FM mono blaring from the single dash speaker. Went with a couple of buddies, a '66 'Stang and a really cool '40 Dodge "special deluxe" D16 sedan.409941004101
Nice Harold
  1969 Coronet A39 Super Bee Scat Pack Spring Special option code 1958300 2 22 08-22-25, 11:48 PM
