Weird lights issue. Some guidance?
#31
When you say sockets what do you mean?
67 440 4 Door Coronet with a 318 polyblock.
[SIGPIC][/SIGPIC]
Where the bulbs plug in. The metal on the socket is the ground for the bulb. If the socket or the taillight housing is corroded or doesn't fit snug, you'll get a bad ground and either a dim bulb or none at all.
67. So you mean the outside part of the plug? It fits very tight so that's not the issue. I could def see it being corroded. How would I go about cleaning each side? The same steps expalined above for cleaning the fuse box?
[SIGPIC][/SIGPIC]
Ayup..
Awesome thanks. Going to be cleaning both ends this weekend. Weather permitting.
[SIGPIC][/SIGPIC]
From the sounds of it? Crappy connections and crusty light sockets I bed to be your troubles.
My advise is. Go 1 light at a time and replace the sockets. Yes you can buy new sockets at NAPA. Remove the light housing and you will see how the socket is pressed into the pot metal light fixture. It will come out with a little effort. The rear lights would talk a 1157 bulb socket. Not sure up front? Once new sockets are in place SOLDER your connections. !! Take your time and do it right..
You will get there and learn a thing or two.... Good luck
I would also pack some Deletric grease in all the sockets, that should prevent any corrosion from forming, you can get it in tubes at any parts store, Autozone, Advance.
Without reading the whole thread
I had the same thing happen to me once
It was the lic. plate light I cut the wire
everything worked then
  Cornering lights? Kingspagetti 0 659 08-01-22, 11:57 AM
Last Post: Kingspagetti
  Small annoying issue with my Floor shifter - 727 Trans TekHousE 6 3,401 09-02-15, 04:07 AM
Last Post: TekHousE
  Speedo Issue elevatorman 0 3,060 09-01-14, 04:47 PM
Last Post: elevatorman
  no dash lights, no gas gauge, spooky...... uncledon 43 20,033 06-12-14, 03:11 PM
  NEW PROCESS A-833 TRANSMISSION ISSUE Markfive 4 4,950 08-19-13, 06:35 PM
Last Post: 4264door
  Lights out, and always on E Piper 14 7,638 06-19-13, 01:38 PM
  Starter Relay / Ignition issue Zaq 9 5,390 06-04-13, 05:33 PM
Last Post: 71_deputy
  Wiring Issue markbob@ameritech.net 3 3,553 05-31-13, 04:42 PM
Last Post: markbob@ameritech.net
  Strange charging issue rlsbee 2 3,331 03-14-13, 12:00 PM
Last Post: FRATZOG
