Rebuilt both passenger side door hinges - thanks for the tip Rich!
Thanks, my stubbornness, and other known problems led me to buy an exhaust bender this spring. Haven't used it yet, but can't wait.
ws27 Wrote:Thanks, my stubbornness, and other known problems led me to buy an exhaust bender this spring. Haven't used it yet, but can't wait.
That would be a pretty nice piece to own...
Rich, you can set up shop now, the orders from this site will be pouring in!!!!!!!!!!!
Nothing
[Image: CRYING.gif]
I need to set up an outlet and just play with it a little.
Then the first Guinea pig... Jim's wagon. HEHEHEHE
67r/t4speeder Wrote:Nothing
[Image: CRYING.gif]
No sympathy here buddy. LOL
It was only 2 deg Celsius (not quite 36 deg F) this morning, but I drove her to work anyway. Smile
Over the weekend I finished plumbing my dual pot master, bled the brakes, found a pinhole leak in one of the lines, replaced that line, bled them again, installed a new drive shaft, installed a B&M shifter, filled rear end with gear lube, added transmission fluid to find it it drips from one of the cooler lines (no surprise, anytime I add a new fluid to the car it leaks out somewhere until I can fix it).
Only thing stopping me from taking it for a spin around the block is waiting for a thermostat gasket because the store had to order one. It will be the first time it has moved under its own power since 1981.
Zaq Wrote:Over the weekend I finished plumbing my dual pot master, bled the brakes, found a pinhole leak in one of the lines, replaced that line, bled them again, installed a new drive shaft, installed a B&M shifter, filled rear end with gear lube, added transmission fluid to find it it drips from one of the cooler lines (no surprise, anytime I add a new fluid to the car it leaks out somewhere until I can fix it).
Nice, can't wait to till you get it running.
18 Guest(s)
