67r/t4speeder Wrote:Week has been nut's at work so no Max for me this week.
[Image: crying-baby.jpeg]
RoflRofl
Thank you Racer Brown.. I hope it's as nice as it looks..i will let you know soon and post some pics once it's installed..."Before and After" shots...God Bless ya...Barry.
[SIGPIC][/SIGPIC]67 Coronet 440.. 225cid. 3 Speed column shift..!!.Confused
I ordered parts for it so next week I can put a HEI dist and change transmission fluid.
I thought it would finally cool off enough in Vegas to spend a day in the garage.. I was wrong! I stuck it out though and nearly gave myself heat stroke!
on a good note, I (sortof) realigned the passenger door (what a pain in the ass and its still not quite right!) installed door handles, window kit, new molding, window channel trim, fuzzy kits and dynamat on the inside of the door.
Felt good to finally getting in the garage again, but trying to realign that door (solo) left me sore at the end of the day!
Today i am going to try and get more trim on her but we will see how it goes. I need to hunt for some clips for the window trim.
Does anyone know what the part number is for push in clips? (upper window trim - see arrow)? I need to install the trim but only have a few of the clips.
[Image: clippartnumber_zpscd437ed0.jpg]
Went through 1/2 tank just driving around back roads enjoying the nice sunny day .
It's kind of scary.. but I actually worked on mine..
2718
I finished stripping, cleaning and painting the horns and installed. Detailed the windshield squirters, installed all new washer hoses, the pump and bottle. Started final adjustments to the wndows and top.
stamm321 Wrote:I thought it would finally cool off enough in Vegas to spend a day in the garage.. I was wrong! I stuck it out though and nearly gave myself heat stroke!
I'm feelin' ya Robert!
theman440 Wrote:I finished stripping, cleaning and painting the horns and installed. Detailed the windshield squirters, installed all new washer hoses, the pump and bottle. Started final adjustments to the wndows and top.
I hope you have a swamp cooler in your garage!
The part numbers would be a job for Richard.....Hey Richard, whats the part # for push in clips,upper window trim.?66 Net.
Good job on realigning your door.they are a pain..i tried it once and just tightened everything back up.before I really screwed it up.ha,ha..some other day ill try it again.....awesome job though,looks great.!.
33 Guest(s)
