Modern Hemi swap 66 Cornet 500
#31
isn't the poly bellhousing pattern the same as a BB?
I have heard also but not positive
I'm not positive but wanted to keep it in the back of my mind just in case.
The Poly has the same bell housing pattern as a LA engine (small block)
I'd have to vote for the 440 first and the 383 second Tom, but I'm an "old school" kind of guy.
[Image: My1966Coronet500-5-23-2013-3.jpg~original]
theman440 Wrote:The Poly has the same bell housing pattern as a LA engine (small block)
X2
one bolt on the bell housing will not line up. But that's no big deal.
I've got everything in motion for the 440. I will have it either this weekend or next and will start tearing into it in the next few weeks. I'll be sure to post pics and updates of the build and let you guys know how it goes. Thanks for all the input! Your car is absolutely gorgeous Richard!
That's fantastic Tom! Cool
Why don't you start a thread in the DCR Restoration forum so you can document your 440 build and other projects that you might be doing in the future. That way we can all follow your progress all on one thread! Smile
By the way Tom, regarding the driveshafts in the 1966 Coronet models, there is some good news and some less than good news.
According to my 1966 Factory Parts Book, it looks as if some of the various 318 Poly, 361, 383 and a few other engines using either a manual or automatic transmission along with an 8 3/4" rear differential use the same length driveshaft in the 1966 Coronet models with the exception of the station wagon models. The less than good news is that the 318 Ploy equipped Coronets use a smaller 2 3/4" diameter driveshaft while the big block 361 and 383 equipped Coronets use a bigger 3 1/4" diameter driveshaft. Back to the good news though, instead of you having to purchase a more expensive aftermarket driveshaft, you can go to a wreaking yard in your area or search online and look for a 1966 Coronet 2 door hardtop, 2 door sedan, or 4 door sedan that is being parted out that was equipped with a 361 or 383 and go with that. Just check it for straightness and any damage and replace the u-joints and you're good to go.
Due to possible copyright law infringements here on the DCR Tom, I'm unable to post any information directly from the 1966 Factory Parts Book concerning the various 1966 Coronet driveshaft specifications, but I will send you a personal message later today here on the DCR and we can talk further ok?
Fraid I must disagree with you there Richard.. But according to this, all driveshafts in 66 were 2.75" in diameter, unless you got the 426 motor. Then it got bumped up to 3".
8256]
  Modern type headliner RT K_line 3 17,215 11-28-16, 11:53 AM
  A500/518 OD swap 67r/t4speeder 29 25,888 11-18-16, 03:24 PM
  5.7 hemi conversion into my 67 Coronet 500 project thread uncledon 22 17,542 08-03-15, 07:25 PM
  Modern 5.2 in a 50's ??? ghost 2 5,418 04-17-14, 02:43 PM
Last Post: ghost
