Modern type headliner
I have installed a modern type headliner on my R/T. I used a sheet of corplast to do it. About $10.00 a sheet. I had already installed some insulation in between the supports. Temp dropped 15 degrees with the insulation in direct sunlight. Now it has a modern look. Corplast is basically a plastic cardboard structure. I just used yellow weather stripping adhesive to glue it to the Inslation. I also used my light from my 95 nissan hardbody pickup for the interior light. I like how it came out. Here are some pictures.
I`m loving that looks great. Will the original trims work with it?
Yes all the chrome trim for the interior went back on with no problem. The only issue I have was I couldn't get a wide enough piece of material to make the sail panels and top one piece. I'm trying to come up with an idea to cover the joint. I'm thinking just a strip if material would work.
You can see what I'm talking about in my thread My project R/T on the first page.
Lookin good
  Modern Hemi swap 66 Cornet 500 Tom66-500 41 26,867 04-18-16, 05:04 PM
Last Post: Tom66-500
  Modern 5.2 in a 50's ??? ghost 2 5,418 04-17-14, 02:43 PM
Last Post: ghost
