A500/518 OD swap
Has anyone on here put one of these OD trans behind there cars? I have seen a couple big blocks done with the aftermarket bell, but you would think a 3.9 to a LA would be close to a bolt on ??
I am ending up with a 500 out of a `89 Dakota V6 3.9 so I was considering putting it in place of my 904 in Jr if possible. One step closer to having a Carlisle runner .Wink
3.9 to LA should be a bolt on. I think you will need to wire in a switch to control the OD. Ive read into this swap a little bit and people have done it. So you should be able to find info on it. I'm pretty sure you will need to modify your trans tunnel and fab your own trans mount.
7933]Here is my donor A500 out of a Dakota to replace my 904 in `67 Dart. I will save all the wiring and dash switch to maybe use. First I will check out condition of transmission even thought it worked perfect it is old.
An excellent write up full of info::: http://www.dippy.org/forum2/index.php?topic=231.0
That is a good write up, has everything you need to know.
I wanted to post more hook up info that I found useful
http://www.transmissioncenter.net/SwapInformation.htm
http://www.hemmings.com/magazine/mus/200...01453.html
more reading
8960]
A500 vs 904
How much you figure you gotta get the driveshaft cut?
67440Dodge Wrote:How much you figure you gotta get the driveshaft cut?
6 1/2 inches but I will recheck after I get it in place.
  Modern Hemi swap 66 Cornet 500 Tom66-500 41 26,867 04-18-16, 05:04 PM
Last Post: Tom66-500
