Lower Ball Joint Replacement
Is it a good idea to take some preload off of the torsion bars before trying to separate the lowers?
Avenger Wrote:You got that right lol. Still havent gotten the chance to even start. Had projects and such every weekend. This weekend is replacing a leaking element in my water heater and hoping that nothing gets busted in the process resulting in a new tank. If it happens it happens though lol.
I just went thru that.. so clogged with lime they wouldn't heat the water. Just make sure to open a hot water faucet when you open the drain on the tank, that'll help it drain faster. If nothing comes out the hose and you got a compressor, blow some air back in the hose, it's probably clogged with lime deposits and that'll keep it from draining.
Piper Wrote:Is it a good idea to take some preload off of the torsion bars before trying to separate the lowers?
No need if the LCA is supported with a jack. If not, in for a rude awakening when it seperates.
  Lower control arm question Piper 2 19 10-17-23, 01:57 PM
Last Post: revel68
  Best wiring replacement Dionisio -C- 28 13,988 06-07-17, 12:51 AM
Last Post: Dionisio -C-
  Driveshaft / U-Joint Tech 1967 Coronet 500: SUMMARY Hibbing_Coronet_500 16 8,715 09-10-14, 02:10 PM
  Driveshaft / U-Joint Tech 1967 Coronet 500 Hibbing_Coronet_500 44 18,126 08-21-14, 08:31 PM
