Fuel gauge has me stumped.
I re read your post again and Im sure its a tank/sender GROUND issue.
Hibbing_Coronet_500 Wrote:I re read your post again and Im sure its a tank/sender GROUND issue.
Thanks for the suggestions. Ground is good. The battery is in the trunk and I grounded the sending unit right to negative on the battery.
Got out it working now. New sending unit fixed it right up.
  Temperature gauge Avenger 7 6,141 09-08-16, 01:07 PM
Last Post: Avenger
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
  Fuel filler leaking cnmsales 5 4,006 12-18-15, 06:01 PM
Last Post: Drag-Net
  Fuel pressure of a stock 318 tkarman 2 3,148 05-22-15, 03:26 PM
Last Post: tkarman
Last Post: harold prentice
  discoverd oil pressure gauge tucked up under dash... DannyHavs 2 3,947 06-24-14, 11:59 PM
Last Post: DannyHavs
  no dash lights, no gas gauge, spooky...... uncledon 43 20,037 06-12-14, 03:11 PM
