car won't start
Distributor installed 180 degrees out?
There is absolutely no firing at all. Could be the spark plug reach, also he has a little back flow through the carb during cranking.
Had a carb fire yet while cranking?
ws27 Wrote:There is absolutely no firing at all. Could be the spark plug reach, also he has a little back flow through the carb during cranking.
I put the longer plugs in, sounds a little better can hear a couple little pops here and there but still lethargic. I adjusted the rockers (first time 1/4 turn) this time just took slack out and tightened the adjustor (thought being the valves were hanging up). No go, its a fresh battery as well. Its now being suggested I go 1/2 turn after I take the slack out.
not sure gents...going to try the latter tomorrow
Watch towards the end, gas is spraying the motor and fresh paint.
http://youtu.be/FTLWyiKMMjg
Link no workee.
Got all your grounds in place?
Friend stuck grape fruits in header collector ?
Top dead center #1 valves are closed ?
a major vacuum leak? At carb possible ?
Do a compression check on a couple
I think you might have a valve timing issue. It appeared the back blow is with every cylinder. Try to find exact TDC and pull a valve cover to see where the rockers are. Do you think the back blowing is from ignition or compression?
Andy, potatoes work much better, big potatoes.
67r/t4speeder Wrote:Got all your grounds in place?
Got all your grounds in place? Battery Grounded to head via -Cable , perhaps this alone isn't a good enough ground I should perhaps ground to frame as well?
Friend stuck grape fruits in header collector ? Most of my friends are Irish, we deal our pranks out in Potatoes,which none were observed wedged in collector
Top dead center #1 valves are closed ? TDC then 20 Degrees to set rotor to point to #1
a major vacuum leak? At carb possible ?checked, new gaskets and ports are plugged, unless its internal
Do a compression check on a couple Good Idea!
ws27 Wrote:I think you might have a valve timing issue. It appeared the back blow is with every cylinder. Try to find exact TDC and pull a valve cover to see where the rockers are. Do you think the back blowing is from ignition or compression?
Not certain, I wonder since I soaked the lifters in oil for about a week if I don't have them empty enough and its throwing off my adjustment
Did you bleed the air from the lifters after soaking them? Air bubbles can remain if you don't. Just a thought...
  fresh start R/T XTC 18 8,917 04-04-16, 08:57 PM
Last Post: R/T XTC
  Where do you start? Hemi Guy 8 4,892 06-03-13, 09:38 PM
Last Post: Hemi Guy
