Threads: 32
Perfect. Just what we were looking for. Thanks.
Threads: 19
Hi Mike, what do you make that measurement to be?
Threads: 310
Me or the other Mike?
Threads: 19
Either Mike! Side marker to stripe?
Threads: 32
I taped my stripes on today using the photos. Picture #1 shows 3-3/4" (95cm) from the end of the drivers side quarter panel to the first stripe. Picture #2 shows where the measurement in picture #1 was taken. In picture #3 I used a measurement of 3-1/2" (89cm) to the inside of the second stripe. I didn't use picture #4. Picture #5 is basically the same as #3. I used the 3-1/2" (89cm) measurement in #3 because it is easier to see than the measurement to the first stripe. I first taped at the top of the quarter panel as shown in #1, then taped on the side of the fender as shown in #3. Then I repeated on the passenger side. After marking the center (lengthwise) of the middle stripe, it is aligned at both ends with the 2 side stripes. It looks good. Again thanks 67440dodge.
Threads: 310
Glad to help Mike!
Threads: 32
Craig, first of all I'm sure you have already figured out that the measurements I converted were in mm and not cm. When I have the stripe taped on my car using the 3-1/2" measurement, the distance from the side marker light to the first stripe is 8 mm. Good luck!
Threads: 19
Hi Mike, thanks for the measurements. Once I get mine done I'll post pics, hopefully a fortnight or two! If I'd taken those measurements as cm not mm I'd have stripes from front to back of my car! These forums are so helpful.
Threads: 310
Once you post em I'll copy the thread to the archives so others can view it easy..
