Threads: 154
Is a brass bushing and/or a hardened oil pump shaft needed when running a flat tappet cam
I forget if it should, or is that with the billet/rollers?...I was looking at my 440 and its looks like the stock stuff in there
(its running a .528 mech)
Threads: 308
Hardened shaft only needed for roller..
Threads: 49
Unless Dodge is differnt then Chevy, the only diff is you need a brass dist gear . BooBoo .
Threads: 49
Opps , I,m sorry , You need the brass gear on the dist if its a roller cam . Sorry bout that . BooBoo
I thought the hardened pump shaft was only if you are running a high volume oil pump. Does the flat tappet cam do something to the oil pump shaft?
Threads: 154
mostly likely not....i remember having to get both for the 4 speed..because there was "stuff" done to it
