Might be in market for a 4 speed
The old starter was bad..or so I thought
If Im going through any effort to take it back apart it's going 4 speed
Something broke ..eh??
https://youtu.be/dX1n2OatIKM
https://youtu.be/K8s_leGlFX4
What's weird is now I'm thinking about it the last starter snout was also cracked
It acted up in Carlisle, on top of tapping the starter I moved the converter a few teeth with a pry bar and it started..that should have been my sign
I thought the old was just on it's way out
How did that happen? Kind of looks like the bell housing bottomed out on something?
Maybe Something happened in carlisle..that is the same thing it was doing with the old starter and when it started to act up. I'm thinking the converter may have ballooned. I'm looking into what it takes to do a 4 speed swap it looks like the hardest parts are welding the piece on the frame rail for the z bar and the hump area
both of those are easy as no one will look too closely at the welds!
Buy the whole kit from Brewers, it'll save you from having to scrounge parts.
Hardest part on your car most likely going to be the pedal assembly if space is at a premium under there like you told me one time.
Hardest part welding wise is the Z-bar. I used a spare block I had with a bellhousing on it so I could line everything up and then weld it in place.
  Knocked the dust off of the 4 speed today Piper 3 19 09-30-23, 07:33 PM
  318 w 3 speed on the colum still in car BooBoo 0 2,052 04-02-17, 04:20 PM
Last Post: BooBoo
  NEED 68 Coronet RT 440 4 speed Dana car value 4404spd 23 12,733 07-24-16, 03:55 AM
Last Post: 4404spd
  Hellcat World Speed Record on ICE! TekHousE 0 2,350 03-23-16, 11:35 AM
Last Post: TekHousE
  Dodge 727 automatic conversion to a833 4 speed Lipers1 9 6,340 08-04-15, 01:18 PM
Last Post: Warhawkfight34
