Wire cleanup
What is a cleaner way to route the wires for the MSD and fuel pump rather than have them hang off the positive cable? Its a mess in here
How about the large post on the starter relay?
Firewall ground? Also straighten all the kinks out in the wires-will look a lot better.
everyhting is getting redone evetually and those were just run to re arrange some things, I was thinking there was a remote power distribution block or something I could use ..but not sure where
The starter relay is kinda like a remote distribution block. The large post on it is battery positive, the stud usually sticks out well past the nut so there's plenty of room to add more wires for your add-ons.
11658
https://www.rockfordfosgate.com/products/details/rfdb1/
I have something like this on mine, wires still go to battery but it's a little cleaner. I got mine at one of those boomity boomity stereo shops.11659
Auto Zone or Advanced Auto sells a fuse block that takes a single input wire and allows the fused voltage to be distributed from there. I mounted mine on the heater box inside the passenger compartment next to the EFI controller.
11661
Thanks for the ideas guys!
Where's your headlight harness? Don't try driving in the dark! LOL
  Wire clip on the alternator? Anyone have a pic or diagram? 67RTBlue 2 3,815 01-17-17, 09:08 PM
  Plug wire to header clearance-how close is too close 67RTBlue 5 3,949 04-05-16, 09:55 PM
Last Post: Sedanman67
  wire diagram for 67 BooBoo 7 7,105 01-08-14, 11:56 AM
  can't find window washer pump wire on 1967 coronet 440 boydsdodge 9 6,417 05-22-13, 07:37 PM
  67 temp sending unit wire BooBoo 6 4,716 03-28-13, 03:49 PM
Last Post: BooBoo
