Reverse light out
Hi Folks,
Long time, I hope you are all well. Just got her out of storage. Started right up which is good. New is reverse lights are out? No obvious sign of something eating wires. Is there a switch of some sort somewhere that might have failed? All thoughts appreciated as I go hunting.
11429
You may need to get a wiring diagram. I'm not sure where the switch is located on a 65, but my guess is under the dash on the column. Not 100% though. If you need help trouble shooting let me know.
Thank you very kind of you but I got it!
I am no mechanic but figured I could get dirty and follow a bunch of wires and look for something obvious. Started at the back and worked forward. On the back side of steering column was a connector that looked like an after thought. Bolted on in an impossible place to see but the 2 wire connector going to it was hanging off. I thought, "Can't be that easy." Reconnected it and it was. So I got that going for me.
11431
  Dash mounted reverse lamp mounting location? hunt2elk 1 2,370 01-25-19, 04:47 PM
  Tail light panel BigBlock61 5 3,959 07-19-13, 01:55 PM
Last Post: BigBlock61
  Revesrse light switch ? jeffmc 14 7,700 07-16-13, 09:41 PM
Last Post: jeffmc
