Original fuel line 50 dodge
Just recently changed fuel system from pump to tank.when i removed old line, area from rear axle to tank had spring on line.like bending springs.i couldnt remove due to rust.so i slipped rubber hose on new line at area.does anyone know if this was original from mfg time or someone left springs on from old changing?
Yup, that's factory, my R/T had them on, when I restored it I was able to order a new box of it from Chrysler, that was sometime ago, i don't have a part# now. This protected the line from anything that got thrown up agaisnt the line.
Racer,thanks for the info.since was only over axle and bend to tank thought it was used to make bends and just left on
...ans certian portions of the brake lines too.
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  '49 Dodge Emergency Brake (Parking Brake) Handle 50Coronet 1 9,204 10-09-17, 03:13 PM
  Fuel gauge 50net 16 22,132 04-09-17, 12:06 AM
Last Post: 50net
  1954 DODGE ROYAL FUEL TANK SENDING UNIT... PART NUMBER ? onebad54 10 18,318 05-05-16, 12:49 PM
Last Post: onebad54
  50 Dodge coronet sierra steel woody wagon johnson3900 4 5,834 09-01-14, 11:17 PM
  fuel tank plug 50net 2 5,442 05-03-14, 10:16 PM
Last Post: 50net
  '49 Dodge Brake Question 50Coronet 1 4,875 02-20-14, 12:05 AM
Last Post: 48mirage
  Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet 52-Coronet 1 4,149 10-11-13, 07:06 PM
Last Post: 48mirage
