What are these brackets for?
I know that the one on the top is for the wires over the master cylinder. The middle one might be for the starter wire to the apron but I don't know how or where it mounts?
9328]9329]
It mounts near the bottom of the drivers inner fender below the brake master. I think the 3rd one holds the speedo cable.
What the the man 440 said, I would also coat the small one with Plastic-Dip.
Anyone grab a pic of these mounted?
I would like to see how a power brake car wire support looks. This one I think is different being the car was manual? Am I wrong?
I plasti dipped the valve covers. That stuff is dead on to reproduce the factory look. Takes a couple costs but works!
What do you have for a power brake booster. It should the Hemi booster with a passenger side take off master. On mine, the bracket looks stupid, like it doesn't fit because it goes into a notch.
Do these help?9331]9332]9333]9334]
Yes! Strange that the brake line is secured with the small clip. The speedo cable looks to have a clip-on style retainer holding it to the frame rail? I did find some pics on Hoffmanns winners circle albeit a bit different since it's a 68 or 9.
I have an aftermarket "factory style " booster and the master exits on the drivers side. I seen old road test pics with drivers side exiting lines as well on a 440 equipped R/T
67-500 Wrote:Do these help?9331]9332]9333]9334]
Yup, looks good!
  1965 Dodge Coronet 440 Front bumper brackets Moe832 4 5,220 06-23-15, 04:49 PM
