Helpful Tool On Ebay
I just purchased one of these very handy crankshaft harmonic balancer holding tools from Rick Ehrenberg on Ebay. A very simple designed tool that bolts to the harmonic balancer with two bolts and then allows you to insert a square drive 1/2" breaker bar into the square opening on the opposite end of the holding tool to hold the harmonic balancer in place while you're loosening, or tightening the large crankshaft mounted bolt. This tool will work on any big or small block Mopar engine and on both aftermarket and stock harmonic balancers as well.
This tool is currently out of stock
[Image: s-l500.jpg]
Nice Richard
It sure beats having to use other captain caveman ways of holding the crankshaft and harmonic balancer from turning while you're trying to bust that large crankshaft bolt loose or tightening it up. I bet you'd use it often at your shop Andy. Ran just at $31.00 with shipping.
Bump
  Valve Gapper tool 67r/t4speeder 5 19,556 08-30-17, 04:45 PM
  1966-67 B-Body Headliner Sail Panel Boards On Ebay thebankerstoy 14 9,225 06-07-17, 04:45 PM
  Two More Cool Mopar Intake Manifolds On Ebay thebankerstoy 12 8,267 05-16-17, 10:28 PM
  Two Cool Mopar Intake Manifolds On Ebay thebankerstoy 4 4,406 04-28-17, 11:05 PM
  Helpful Tool On Ebay For 4 Speed Owners thebankerstoy 2 3,523 03-26-17, 11:09 PM
  Another Helpful Tool On Ebay thebankerstoy 5 5,715 03-26-17, 03:35 PM
  Mopar Engine Casting Numbers & ID Codes Guide Book On Ebay thebankerstoy 2 3,931 12-11-16, 09:01 PM
  More Ebay Items thebankerstoy 0 3,661 07-12-16, 12:43 PM
  Ebay Items thebankerstoy 3 4,724 07-12-16, 11:21 AM
Last Post: TekHousE
  Reproduction Parts On Ebay thebankerstoy 13 8,945 02-24-16, 07:46 PM
