Steering Column Length
On my 68 Charger I took out the steering column and it was collapsed, the nylon shear pins came out (which set the length of the shaft).
I need to figure out how to get this thing to its original length, any ideas on the length it needs to be or does anyone have one that isn't collapsed?
You mean crumple area is collapsed, and you need to pull it back out? ?
What measurement you need Kev? I'm helping Roy with his 68 tomorrow and can measure.
67440Dodge Wrote:What measurement you need Kev? I'm helping Roy with his 68 tomorrow and can measure.
The shaft on the left is collapsible in case of an accident. I can move it pretty easily by just tapping it.
What I think needs to be done is set it at the correct length, then either tack or JB Weld it so it holds but would still be able to break loose if the car hits something.
8578&d=1466693103[/IMG]
The measurement I can get wouldn't help at all in that situation.
67r/t4speeder Wrote:You mean crumple area is collapsed, and you need to pull it back out? ?
Well the car was never hit, I think I collapsed it by accident
Can you see where dirty area stops when you extend? that would get you real close
The bottom part is compressed so maybe Mike could get a measurement from outer housing to dimple used to measure for coupler setting?
I think the column is the same as 67 at least that was what I was told by some one. What is this, column/console shift, PS,no PS?
ws27 Wrote:I think the column is the same as 67 at least that was what I was told by some one. What is this, column/console shift, PS,no PS?
Power Steering/column shift ...I swapped the column cover to a floor shift.
When I tried to put the wheel on I noticed the shaft keep sinking down (if that makes sense)
  My column shift is out of sync pistolero5150 4 808 10-31-22, 12:19 PM
  Driveshaft length help? dkimwar 7 7,772 05-17-21, 06:21 PM
Last Post: Mark's 69
Last Post: Just Wheels
  Power Steering Pump ID 67440Dodge 1 3,456 05-19-16, 10:57 PM
Last Post: Dave Wallace
  Power steering lines and pump Jpr777 7 4,436 09-25-15, 01:59 PM
  Power steering pump Lipers1 2 2,641 09-08-15, 10:39 AM
Last Post: Lipers1
  Power steering pump Lipers1 3 3,211 09-01-15, 11:38 PM
