Power steering pump
how do you remove pulley from pump? Do I need a puller or does it screw off?
Lipers1 Wrote:how do you remove pulley from pump? Do I need a puller or does it screw off?
Is there a big nut on shaft? I depends on which kind you have.
Pics?
Yes, I have two pumps both are the same one has larger pulley the other has smaller pulley the pump is bad I want to switch pulley's both look like round nuts to hold them on.
Round nuts? Pics will help . If you do not see a six point nut center of pulley you need a special puller.
  Steering Column Length Piper 19 9,903 11-20-24, 08:38 PM
Last Post: Mark's 69
  Power Steering Pump ID 67440Dodge 1 3,456 05-19-16, 10:57 PM
Last Post: Dave Wallace
